Dropdowns not visible when viewport or grasshopper on other screen
I’m having issues, I think, with the DPI settings in Rhino. When I am only using just one window on one display, I can right click to get the dropdown menu in the Layers panel. When I have Grasshopper open or have floating viewport on my other monitor, I cannot see the right-click dropdown menu. Has anyone else run into/fixed this issue?
Thanks!
Hi Aaron - please run the SystemInfo command in Rhino and cpoy/paste the results here.
It sounds like you may be running 2 monitors.
If they are both running the same resolution and same text scaling, Rhino should be okay on either screen.
If the screen resolution or text scaling (Windows settings) are different, then Rhino gets really confused.
Rhino 7 SR18 2022-4-26 (Rhino 7, 7.18.22116.07001, Git hash:master @ 87bfab984a3c0622bb859cff8b5d16be7462b1b0)
License type: Educational, build 2022-04-26
License details: Cloud Zoo
Windows 10.0.22000 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: LAPTOP - Plugged in [71% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-15-2021 (M-D-Y).
Primary OpenGL: NVIDIA Quadro RTX 5000 (NVidia) Memory: 16GB, Driver date: 3-17-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.15
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-17-2022
Driver Version: 30.0.15.1215
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2019.11.5.949\Lumion\Rhino 6.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Users\aaron\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22102.1509
C:\ProgramData\McNeel\Rhinoceros\6.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\aaron\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.3\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.3.0
C:\Users\aaron\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.1\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.1.0
C:\Users\aaron\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.0\Substance.Win.rhp “SubstanceImporter” 2.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.18.22116.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.18.22116.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.18.22116.7001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.18.22116.7001
C:\Program Files\Rhino 7\Plug-ins\Walkabout.rhp “Walkabout”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.18.22116.7001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.18.22116.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.18.22116.7001
Thanks @John. Changing the resolution solved the problem; unfortunately, that makes my current set-up unusable. Is there a way to get around this through a custom scaling or something along those lines?
Maybe Rhino 8 ???
This is a limitation in V7.
There is some hope that for V8 we will be able to handle multiple screens running different resolutions and text scaling better than we do now.
I haven’t seen anything internally to test.
