Dialog Boxes open off Screen
My dialog boxes are always showing up offscreen, some are resizable so when i grab a corner to scale it pops down to be visible. For those that aren’t its a bit trickier. Any thoughts on why this is happening?
Thanks!
Hi Jake -
I’d try the testResetWindowPositions command and see if that sorts it out.
thank you for your response! i was so hoping that would work, as i didn’t know about this command… unfortunately same thing is still happening
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
Any chance you’re running multiple screens at different resolutions or scaling?
Rhino 7 SR14 2022-1-10 (Rhino 7, 7.14.22010.17001, Git hash:master @ d8a2d020be8cb487bfc091316ef32170cfc7eddb)
License type: Commercial, build 2022-01-10
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display and OpenGL: NVIDIA GeForce GTX 1650 Ti with Max-Q Design (NVidia) Memory: 4GB, Driver date: 10-13-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.39
- Secondary monitor attached to adapter port #2
Secondary graphics devices.
Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
> External USB display device with 8 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-13-2021
Driver Version: 30.0.14.7239
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\jchevrier.SMITHGROUP\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\AppUpdate.Rhino (31364060-732b-494c-8ed6-b01233920de8)\2.0.0.0\AppUpdateRhino\Rhino 6\AppUpdate.Rhino.rhp “AppUpdate.Rhino” 2.0.0.0
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2021.3.25.899\Lumion\Rhino 7.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Program Files\pollination\plugin\7.0\Pollination\Pollination.RH.rhp “Pollination.RH” 1.3.2.0
C:\Program Files\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino6.Plugin” 0.0.22094.1322
C:\ProgramData\UNIFI Labs, Inc.\Rhino\UnifiLabs.RhinoAddin.rhp “UNIFI Rhino Plug-in” 0.0.2.0
c:\Program Files\Solemma\ClimateStudio\bin\ClimateStudioRhino.rhp “ClimateStudioRhino” 1.7.8145.24039
C:\Users\jchevrier.SMITHGROUP\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\LadybugTools\1.36.135\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.36.135.0
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\Pollination\1.3.2\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.3.2.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.14.22010.17001
C:\Users\jchevrier.SMITHGROUP\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2020.12.9.865\PanelingTools.rhp “PanelingTools”
That is correct, i didn’t realized they were scaled different, but yes, perhaps i have a pretty nontraditional monitor setup…
Rhino 7 does a poor job on handing multiple screens, unless they all are using the same resolution and scaling. Then it’s fine. That’s what I’m doing.
I believe I heard that the developers are working on handling this better for V8.
thanks for the tip @John_Brock! I’ll try that out in the meantime, but yes hopefully v8 will solve this.
