Drop box 3dm
Bonjour,je n’arrive pas à ouvrir un fichier 3dm Dupuis ma dropbox
Can you tell me which version of iRhino are you using? and are you getting an error message?
Rhino 7 , fichier non pris en charge.
I meant which version of iRhino3D app are you using. And can you share the file that’s giving you this issue?
Thanks
Try renaming the file extension to “3dm”.
Any luck?
John is right. Renaming the file extension to 3dm will do it.
I’ll make sure to support 3dmbak extension in the next release
Logged here:
https://mcneel.myjetbrains.com/youtrack/issue/RV-1084/Support-3dmbak
@Henry_Fournier
Please be aware that the 3DMBAK version of the Rhino file is NOT the most current.
When the last editing session in Rhino was saved, those new changes were saved into the 3DM file, and the file version prior to those last edits was saved as the 3DMBAK file.
Thanks very much it is right with 3dm
