Drawing problem
Hi! I have been using Rhino for a while and I always have a reaccuring issue (might be something silly but I can’t solve it on my own).
When I am drawing a curve, it looks good in one view but then it seems that some points are not in the same line in the different views. I already tried with the planar mode on or off, but the problem stays. So for example i want to draw a heart, i start with a curve (flat) but then it appears that 2 points are not in the same plane and I don’t know how to fix it.
Another reoccuring issue is that when I want to move an item to a certain point , it is correct in one view, but then it jumps to another position in another view.
Any experience with these issues? Hope I explained it clear. Thanks
Here is the curve that I am talking about
You can fix this issue by using SetPt and checking the Z option.
This issue you’re facing is likely due to not enabling the Planar modeling aid option. You can check it, and this options is located in the status bar as show in the image below,
Thank you for the quick reply! I’ll try it
