Why when i try to draw 2d drawing but its mistakenly became 3d
what mistake I’m doing it happens always
i just do the 2d drawing all side of room in top view and rotate for elevation in perspective and then i switch to top view its seem some mistake in top view
I still get bothered by this as well.
Why wasn’t that constrained to the plane of the first point - what am I missing here?
@from_outland pls run _SystemInfo in Rhino and post back the results.
@ftzuk
and
Ok but that’s not what the help file says? The PLANAR option enabled should work as advertised - it’s a pain the way it’s implemented imo.
This is off-thread.
Many different modeling tools have a priority order.
Even ortho constraint your next picks/clicks to determined directions, unless you snap with Osnap, in that case Osnap take priority and Ortho is ignored, even if ON.
With Planar I guess it’s similar.
You can see Planar as a “weaker Ortho” that only constraints to your first pick CPlane Z coordinate.
Changing priority order would surely cause many users complaints, as Rhino behave this way since… many years.
There is no right/wrong. It is what it is.
Planar < Ortho < Osnap < Project
irontown.3dm (3.0 MB)
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 16GB)
.NET 8.0.14
Computer platform: LAPTOP - Plugged in [55% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 7-29-2021 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce GTX 1650 Ti (NVidia) Memory: 4GB, Driver date: 10-19-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 621.01
Integrated accelerated graphics device with 1 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-19-2026
Driver Version: 32.0.16.2101
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
i only understood this part
still idk which one is solution
can u send a video ?
the thing you are seeing are vertical lines seen from above. I’m not seeing them stick out the way you do though. They should appear as 1 pixel in top view. Here are the verticals with horizontals locked on my side:
Do you recall this wasn’t an issue for you in an earlier service release?
It does:
ya
my bad :sweat_smile:
i though that vertical line was cross but its 90 degrees only now I am realizing
that y i raised the question
