Hi
I have a flower / flower shoot made in clay, which I would like to sketch 1:1 in Rhino. It’s 2cm(L)*2cm(w)*1cm(h)
I’m new to the program, and can’t really figure out how to start. Can anyone help me out with some suggestions?
Kind regards
Hi @Tine_Tourell_Søderbe
That’s no easy task for a beginner, but go for it and jump in the deep end! My best piece of advice would be to go for Sub-d modeling, as it’s well suited for something this organic. In order to get started, no better place than the resident Sub-D-teacher/design-oracle @theoutside (well, his real name is Kyle) and his hand tutorial - look here, give it a shot - and if you get stuck, feel free to post what you’ve got, and I’m sure somebody will try to help you out Also, if you look at Rhino’s Youtube channel, there are a quite a few more Sub-D related videos - check them out as well!
HTH, Jakob
Really helpful with the hand video. 1 question: what is your “smooth” setting? I’m referring to the part where you go from sharp edges / curves to smoothing the hand. My flower doesn’t get as rounded as yours, so I assume it has something to do with my “smooth” settings
Thanks (
Hi, if you are going to sketch it, then you can put the picture in the orientation you chose to draw it in. Then you can use some of the curve drawing tools available to eventually trace over it, whether it be in a plan view or a side view. Is that what you are asking?—-Mark
@wim@theoutside
Maybe i did something wrong then. I tried to follow your “hand tutorial” and do the same for the flower. When wanting to smoothen it, like you do with the “hand” to make it more round than sharp/straight lines, it looks like this
Where in Kyle’s video is he using the Smooth command?
To go from the the non-smooth version to the smooth version of a SubD object, you need to use the SubDDisplayToggle command, which should be mapped to the Tab key by default.
@wim
Oh no, you’re right. I misunderstod. He talks about smoothening 9:50mins in, but now I get that it’s just the “tab” key and not actually writing “smooth” in the command line. Thanks a lot
