I started to use Rhino a week ago because i needed to change the software that i worked.
I’m still getting used to all different tools and i’m having difficulties on how to approach them.
My project is a vase and in the other software i would sweep it and then made a pattern or an arraycrv.
However, if i try it in the same way i don’t get the same result.
For example, in the first picture i need the shape of the sweep to be tanget to the green line.
The vase has specific dimensions that i need to use. I was thinking what is the best way to do it and if it is better to model it in grasshopper since i need to follow those dimensions.
Thanks !
Thanks for the tips !
I need to get used to the SubD tools because i didn’t work with that kind of features.
I have another question if you can awnser: with SubD tools it’s better to start with primitive shapes like cones and cylinders, or is it better to do like i did above and then adjust the edges ?
Alright !
i’ll do with SubD to practice when i resolve that sweep problem. I think that it’s a great method for my type of projects.
thank you very much !
