I currently work on double-curved shells. I created a 2-sided (supported) anticlastic shell, but I need a 3-sided surface as shown in the image. Can you help me, please? I need your assistance.
Mr. @adel.albloushi, I need your help. If possible, can you investigate my definition to make it? I am not a professional in GH. anticlastic.gh (22.9 KB)
here is something to get you started. the curves are second degree, unweighted, so they are not hyperbolas - you will need to adjust that if you want hyperbolas, or any other type of curves/surfaces.
Thank you so much, Adel. It works nicely. I wonder if there are parameters to change the dimensions that I mark in the picture. Since then, I will use them for form optimization through Galapagos.
I have a last question. I will make a structural analysis of the shell with Karamba. Because of that, I need the support points on the shell. Is there a way to select these points separately?
I have a problem with the final geometry. When baking the final component, the geometry is not a single surface. I need a single surface to adjust manually the voxel dimensions on the surface with the Crystallon plugin. Is there any way to create an untrimmed single surface?
