Surface with double radius of curvature
Hallo dear community,
I have a dummies question.
Is it possible to parameterize in GH, an existing surface from Rhino and make it possible to modify the surface with a double angle of curvature, passing on the axes of its isocurves?
Greeting,
J. Rob
Hi John,
I think we’re going to need an image of some sort to follow what you mean here.
Hallo Daniel, thanks for the interest.
Here a screen and a GH file with the example.
Chips.gh (153.5 KB)
I need to modify flat surfaces with a surface with double curvature radius, (p.e 20m Radius) in the Iso-axes.
Thanks in advance
I used patch for creating the surface through the given curves. it’s a bit slow to compute but it works.
Chips_Re.gh (168.8 KB)
Thanks for the interest Mahan,
sorry my ignorance, with this procedure, I can’t understand how to give the radius of curvature.
JRob
Sorry, I expressed myself badly.
Double bending radius and not double bending angle.
-Those two NURBS curves are not Arcs. Therefore they don’t have radiuses. But you can control the their curvature with " curve control" slider which I put in the file.
-In case if you want those curves to be Arcs you can create arcs instead of NURBS curves.
Chips_Re_Arcs.gh (160.5 KB)
Thanks a lot Mahan,
so it works perfectly!!
Many Thanks
J. Rob
