This is on a monitor which is part of a double monitor configuration. The sizing grips are visible on the other monitor so the window can be resized, but it’s awkward. This happens with any objects containing editable text. There may be other instances of the problem which Ihaven’t discovered.
What is your DPI scaling in the windows display settings?
This setting doesn’t say dpi anywhere but maybe it’s what you’re suggesting, tay.0…
The 2560 x 1440 peripheral monitor I’m using Rhino on:
The Laptop’s 8k monitor:
Yes … I think the issue is case by the 250% laptop monitor, can you change it to 300? This can have a huge effect on the UI
