Layer Panel on 2nd Monitor changes size
Using Rhino, when I switch to any other program the bloody Panel size on the 2nd monitor changes size, I believe that it is echoing the monitor resolution on the main monitor, which throws the entire bloody thing out of wack.
Bloody annoying as it hampers the work flow, and I am already in a time sensitive environment
is it my computer settings (my problem) or a glitch?
In your Windows Display settings, are the two monitors running at the same resolution and text magnification?
