can we have a dotted line on the plane when there is a beam above?
Thank you
Thank you
Hi Hugues,
You could see a beam placed above the cut plane represented as a line changing the Plan Visibility setting to “Inside level” or “Above cut plane”, but this is not working right now. I’ll let you know when we fix this.
Ok thank you
@hugues_tournier the plan visibility settings are working fine in the VisualARQ 2.8 version we have just released. You can also define some overhead attributes when objects are displayed above the cut plane. Check this out: https://youtu.be/fJSbR_gutzs
