Visibility
Plan Visibility is currently set to "Projection with “Overhead”. However, when a beam is selected, overhead is shonw, but when the selection is deactivated, it’s gone. How can I have it shown in plan
I can see overhead in Rendered, Gohosted, Artistic, Pen, Arctic, Raytraced, Conceptual, and Realistic display mode, but it’s nowt shown in other mode including hidden display mode. I’ve got same error also with VA 2.12.2
Hi. Francesc.
I realized what’s the problem. Background Viewport Color cause this error.
Overhead is not represented properly when it is set to black.
I’ve changed it to white, overhead is shown.
Hi @archist97, you are right. Since the overhead attributes are set to “By Object Display Color”, they should be white like the rest of the beam.
I’ll report that.
