Dot shape properties
Hi everyone,
I am using rhino7 and from installing till now i didnt find where i can change the dot shape.
By default in other rhino versions was dot (circular shape) but in this version is (rectangle), screenshots in attach.
Rhino is updated to the newest version.
How can i change this ?
Hi -
You can’t. Please run the Rhino SystemInfo command and copy-paste the result here.
How you mean… then how its possible my colleagues to have circular shaped dot in rhino7 ?
SysInfo:
Rhino 7 SR17 2022-4-12 (Rhino 7, 7.17.22102.05001, Git hash:master @ 13b57035af8fb22da005ef72c56e4555d9dbcfe3)
License type: Commercial, build 2022-04-12
License details: LAN Zoo Network Node Checked Out
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Primary display: Intel(R) HD Graphics 4600 (Intel) Memory: 1GB, Driver date: 3-8-2017 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 960M (NVidia) Memory: 4GB, Driver date: 12-29-2016 (M-D-Y). OpenGL Ver: 4.5.0 NVIDIA 376.54
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.5 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 12-29-2016
Driver Version: 21.21.13.7654
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.17.22102.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.17.22102.5001
Hi -
I mean that there is something “wrong” with your computer.
Those drivers are ancient. Open the Rhino Notifications panel to get links to the download site for newer drivers.
I have also rhino 5 version and there is ok (circular shape).
So the problem its not with mine computer, but i will also check for the new graphics drivers if there are newer.
The two can’t be compared to each other as apples to apples, since Rhino 7 draws stuff in a much different way.
Ok, the problem is fixed with updating the graphics drivers, @wim thanks.
