Doors and windows tables in inches
Have the option of choosing feet or inch units when working on an imperial template
Hi @miguelayora3,
That is not possible for now but there is a workaround you can follow: you can make the conversion from the file units to the ones you want to show in your table using Grasshopper (https://www.visualarq.com/support/tip/how-can-i-create-calculated-parameters-with-grasshopper/). Once you have made the conversion, you can create two new custom parameters with those converted values to list them in tables instead of listing the original ones.
