Does VisualARQ’s wall support trim/extend?
As far as I can tell, Rhino does trim/extend.
VisualARQ’s vaWallExtend is like Revit’s Attach Top/Base.
Hi @Jim_Sung , you can use the wall extension arrows to stretch and extend walls horizontally.
You can also use the vaSplit command to trim a wall from a specific point.
In VisualARQ 2.13 it will be possible o extend walls to other walls with a command driven by the Grasshopper Player. This is a sneak preview:
