I was using a jpeg on a picture frame as a background image. While navigating around in the perspective window, the image suddenly became very distorted and would scale wildly as I zoomed in and out. I had the picture frame on a separate layer that was locked. This happened even when I reverted to a saved copy of the file. It finally cleared up before I could get a screen capture to illustrate the problem. Has anyone else encountered this behavior?
OK. The Quadro is a good card.
You’re drivers aren’t the latest but they aren’t ancient either.
Have you made the two recommend nVidia Control Panel settings changes detailed at the bottom of this support document? http://wiki.mcneel.com/rhino/nvidiainfo
Thanks John. I made the two recommended adjustment in the control panel. I hesitate to update the driver since it took me some effort to find a driver that worked with my computer and Windows 10. I haven’t noticed any distortions to a picture frame image lately. Fingers crossed.
