Hey guys, as a beginner in grasshopper I try to explain my Problem: I lofted to curves, so I got a Surface. Then I used the box Contours (xy-plane), followed by dividing those contours. Those divisions now have always the same distance. My goal is to achieve a “flow” from a small distance between the division-points at the beginning of the contour-curves (on the right hand side) to a bigger distance between the division-points at the end of the contour-curves (on the left hand side).
I hope I could explain what I want to do. Thank you!
