Display user attributes by default
I’m using user attributes a lot and I was wondering if there is a way to make a properties tab that keeps the Attribute User Text tab active by default?
Right now, I can create a new file or open an existing and go to the tab once and it remembers my choice within that file. My tab choice is not saved with the file and it seems as if it cannot be saved with a template either.
It would be great if Rhino remembered this…
Hi Martin,
from Rhino 8 on you can open a second properties window, and switch the second one to attributes, which stays at attributes after reselecting the object.
Best regards
Michael
Hi Michael, I do have a second properties tab open already but inside the tab Rhino doesn’t remember the chosen tab (Attribute User Text).
After opening a new file, I need to navigate to the Attribute User Text icon once and then it stays for this file until I close it.
Anyone aware of a Plugin for this. Would be useful to have this :slight_smile:
I’m also struggling to fix the Attribute User Text panel (macOS). Has there been any update on this?
Currently, if I want to view or work with the Attribute User Text, I always have to first select the object, then manually open the Attribute User Text sub-panel inside the Properties panel. And every time I change the selection, I have to open it again from scratch.
It would be great to have the possibility to pin or keep certain sub-panels open within the Properties panel, or even better, to undock specific sub-panels — like Attribute User Text or Hatch Properties — as standalone floating panels. That way, they stay accessible while switching between objects.
Best,
Pip
