Hey legends, slightly different topic, just downloaded WIP for MAC and it doesn’t look quite right…
try > option > view > opengl > gpu tessellation
I found the opengl under preferences, Im still confused. Does this issue relate to my graphics card? My mac supports OpenGL 4.0.
Does this information assist with determining any further advice?
Software information
Software versions
Rhinoceros version: 6 WIP (6.10.18248.08016, 2018-09-05)
Rhinoceros path: /Applications/RhinoWIP.app
IronPython version: not installed
WIP expiration: 20 October 2018
Language: en-AU (MacOS default)
macOS version: Version 10.13.6 (Build 17G65)
Plug-ins
/Applications/RhinoWIP.app/Contents/MacOS/Rhinoceros
/Applications/RhinoWIP.app/Contents/Frameworks/OpenNURBS.framework/Versions/A/OpenNURBS
/Applications/RhinoWIP.app/Contents/Frameworks/CustomViews.framework/Versions/A/CustomViews
/Applications/RhinoWIP.app/Contents/Frameworks/RhCommon.framework/RhCommon
/Applications/RhinoWIP.app/Contents/Frameworks/libxammac.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework/RhMaterialEditor
/Applications/RhinoWIP.app/Contents/Frameworks/RhCommonRDK.framework/RhCommonRDK
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp/Contents/MacOS/NamedSnapshots
/Applications/RhinoWIP.app/Contents/Frameworks/libccycles.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libOpenImageIO.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libboost_thread-mt.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libboost_system-mt.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/Alerter.rhp/Contents/MacOS/Alerter
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp/Contents/MacOS/AnimationTools
/Applications/RhinoWIP.app/Contents/PlugIns/CreaseAngle.rhp/Contents/MacOS/CreaseAngle
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp/Contents/MacOS/Displacement
/Applications/RhinoWIP.app/Contents/PlugIns/export_3DS.rhp/Contents/MacOS/export_3DS
/Applications/RhinoWIP.app/Contents/PlugIns/export_3MF.rhp/Contents/MacOS/export_3MF
/Applications/RhinoWIP.app/Contents/Frameworks/lib3MF_darwin.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/export_ACAD.rhp/Contents/MacOS/export_ACAD
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Gi.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/TD_Tf.tx
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Db.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Root.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_AcisBuilder.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_BrepRenderer.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_DbRoot.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Alloc.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_BrepBuilder.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libsisl.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Ge.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_SpatialIndex.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Br.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/TxHostLib.tx
/Applications/RhinoWIP.app/Contents/Frameworks/RecomputeDimBlock.tx
/Applications/RhinoWIP.app/Contents/Frameworks/PlotSettingsValidator.tx
/Applications/RhinoWIP.app/Contents/Frameworks/ModelerGeometry.tx
/Applications/RhinoWIP.app/Contents/PlugIns/export_AI.rhp/Contents/MacOS/export_AI
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CD.rhp/Contents/MacOS/Export_CD
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CSV.rhp/Contents/MacOS/Export_CSV
/Applications/RhinoWIP.app/Contents/PlugIns/export_FBX.rhp/Contents/MacOS/export_FBX
/Applications/RhinoWIP.app/Contents/Frameworks/libfbxsdk.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/Export_GTS.rhp/Contents/MacOS/Export_GTS
/Applications/RhinoWIP.app/Contents/PlugIns/export_LWO.rhp/Contents/MacOS/export_LWO
/Applications/RhinoWIP.app/Contents/PlugIns/export_Points.rhp/Contents/MacOS/export_Points
/Applications/RhinoWIP.app/Contents/PlugIns/Export_POV.rhp/Contents/MacOS/Export_POV
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RAW.rhp/Contents/MacOS/Export_RAW
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RIB.rhp/Contents/MacOS/Export_RIB
/Applications/RhinoWIP.app/Contents/PlugIns/export_SAT.rhp/Contents/MacOS/export_SAT
/Applications/RhinoWIP.app/Contents/PlugIns/export_SKP.rhp/Contents/MacOS/export_SKP
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/SketchUpAPI
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonPreferences.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonUnits.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonGeometry.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonGeoutils.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonImage.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonUtils.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/Libraries/libCommonZip.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/export_SLC.rhp/Contents/MacOS/export_SLC
/Applications/RhinoWIP.app/Contents/PlugIns/export_STEP.rhp/Contents/MacOS/export_STEP
/Applications/RhinoWIP.app/Contents/Frameworks/librose.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/libstpcad.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/export_STL.rhp/Contents/MacOS/export_STL
/Applications/RhinoWIP.app/Contents/PlugIns/Export_UDO.rhp/Contents/MacOS/Export_UDO
/Applications/RhinoWIP.app/Contents/PlugIns/export_VDA.rhp/Contents/MacOS/export_VDA
/Applications/RhinoWIP.app/Contents/PlugIns/export_VRML.rhp/Contents/MacOS/export_VRML
/Applications/RhinoWIP.app/Contents/PlugIns/Export_WAMIT.rhp/Contents/MacOS/Export_WAMIT
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X.rhp/Contents/MacOS/Export_X
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X3D.rhp/Contents/MacOS/Export_X3D
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X_T.rhp/Contents/MacOS/Export_X_T
/Applications/RhinoWIP.app/Contents/PlugIns/Export_XGL.rhp/Contents/MacOS/Export_XGL
/Applications/RhinoWIP.app/Contents/PlugIns/IgesCoreLib.rhp/Contents/MacOS/IgesCoreLib
/Applications/RhinoWIP.app/Contents/PlugIns/import_3MF.rhp/Contents/MacOS/import_3MF
/Applications/RhinoWIP.app/Contents/PlugIns/import_ACAD.rhp/Contents/MacOS/import_ACAD
/Applications/RhinoWIP.app/Contents/PlugIns/Import_DGN.rhp/Contents/MacOS/Import_DGN
/Applications/RhinoWIP.app/Contents/Frameworks/libTD_Zlib.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/TG_Db.tx
/Applications/RhinoWIP.app/Contents/Frameworks/liboless.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/TG_Dgn7IO.tx
/Applications/RhinoWIP.app/Contents/PlugIns/import_FBX.rhp/Contents/MacOS/import_FBX
/Applications/RhinoWIP.app/Contents/PlugIns/Import_GTS.rhp/Contents/MacOS/Import_GTS
/Applications/RhinoWIP.app/Contents/PlugIns/import_IGES.rhp/Contents/MacOS/import_IGES
/Applications/RhinoWIP.app/Contents/PlugIns/import_LWO.rhp/Contents/MacOS/import_LWO
/Applications/RhinoWIP.app/Contents/PlugIns/Import_M.rhp/Contents/MacOS/Import_M
/Applications/RhinoWIP.app/Contents/PlugIns/Import_OFF.rhp/Contents/MacOS/Import_OFF
/Applications/RhinoWIP.app/Contents/PlugIns/import_PDF.rhp/Contents/MacOS/import_PDF
/Applications/RhinoWIP.app/Contents/PlugIns/import_PLY.rhp/Contents/MacOS/import_PLY
/Applications/RhinoWIP.app/Contents/PlugIns/import_Points.rhp/Contents/MacOS/import_Points
/Applications/RhinoWIP.app/Contents/PlugIns/import_RAW.rhp/Contents/MacOS/import_RAW
/Applications/RhinoWIP.app/Contents/PlugIns/import_SKP.rhp/Contents/MacOS/import_SKP
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SLC.rhp/Contents/MacOS/Import_SLC
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SolidWorks.rhp/Contents/MacOS/Import_SolidWorks
/Applications/RhinoWIP.app/Contents/PlugIns/import_STEP.rhp/Contents/MacOS/import_STEP
/Applications/RhinoWIP.app/Contents/PlugIns/import_STL.rhp/Contents/MacOS/import_STL
/Applications/RhinoWIP.app/Contents/PlugIns/import_VDA.rhp/Contents/MacOS/import_VDA
/Applications/RhinoWIP.app/Contents/PlugIns/import_VRML.rhp/Contents/MacOS/import_VRML
/Applications/RhinoWIP.app/Contents/PlugIns/Import_WAMIT.rhp/Contents/MacOS/Import_WAMIT
/Applications/RhinoWIP.app/Contents/PlugIns/Import_X.rhp/Contents/MacOS/Import_X
/Applications/RhinoWIP.app/Contents/PlugIns/MeshFromPoints.rhp/Contents/MacOS/MeshFromPoints
/Applications/RhinoWIP.app/Contents/PlugIns/MeshTools.rhp/Contents/MacOS/MeshTools
/Applications/RhinoWIP.app/Contents/PlugIns/MPlane.rhp/Contents/MacOS/MPlane
/Applications/RhinoWIP.app/Contents/PlugIns/NamedPositions.rhp/Contents/MacOS/NamedPositions
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp/Contents/MacOS/PanelingTools
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoBonusTools.rhp/Contents/MacOS/RhinoBonusTools
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoLabsTools.rhp/Contents/MacOS/RhinoLabsTools
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp/Contents/MacOS/RhinoRender
/Applications/RhinoWIP.app/Contents/PlugIns/SolidTools.rhp/Contents/MacOS/SolidTools
/Applications/RhinoWIP.app/Contents/PlugIns/Squish.rhp/Contents/MacOS/Squish
Third party kernel extensions
None
Hardware information
Computer hardware
Hardware model: MacBookPro8,3
Processor: Intel Core i7-2860QM CPU @ 2.50GHz
Memory: 8 GB
Architecture: Intel 64 bit
Video hardware
Graphics: AMD Radeon HD 6770M 1024 MB
Memory: 1024 MB
Screen size: 1920 x 1200
Displays: Color LCD (133dpi 1x)
USB devices
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Bluetooth USB Host Controller
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Computer, Inc.: IR Receiver
Bluetooth devices
Apple: Apple Wireless Keyboard
Cambridge Silicon Radio: Headset, Hands-Free unit
OpenGL information
OpenGL software
OpenGL version: 4.1 ATI-1.68.20
Render version: 4.1
Shading language: 4.10
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Stencil depth: 8 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 4x
Mip map filtering: Linear
Anisotropic filtering: High
Hi Stylzin, Hi all!
I have the same problem. It looks like some shades are pointing to the camera.
Stylzin, could you solve it?
This is my configuration (MacBookPro 13" Mid-2012):
Rhino 6 SR12 2018-11-13 (Public Build, 6.12.18317.12076, Git hash:master @ 069b1aed33ba5c9e6b04dd9e509ff8509a57719d)
Licence type: Bêta, version 2018-11-13
License details: Cloud Zoo. In use by: Bris ()
Expires on: 2018-12-28
Apple Intel 64-bit macOS Version 10.13.6 (assemblage 17G3025) (Physical RAM: 16Gb)
Machine name: MacBook Pro
Language: fr
Intel HD Graphics 4000 OpenGL Engine (OpenGL ver:4.1 INTEL-10.36.19)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Driver Date: (null)
Driver Version: (null)
Z-Buffer depth: 24 bits
Total Video Memory: 1536 MB
Displays: LCD couleur (114dpi 1x)
Screen size: 1280 x 800
USB devices
Bluetooth devices
Broadcom: Magic Mouse 2
at.obdev.nke.LittleSnitch (4740) 922754B9-2523-347C-A57E-527E9EA3E43E
com.globaldelight.driver.BoomDevice (1.3) E57A31D6-C32F-3228-A8E7-617B2C67E568
com.globaldelight.driver.Boom2Device (1.1) 7F7523A6-5BE4-3452-9713-BBC88EA4BED3
com.getdropbox.dropbox.kext (1.9.0) 4B7EFBA4-A16C-3856-AA59-AE84D64541C0
com.bluestacks.kext.Hypervisor (5.2.20) 545B8D9E-73B6-3625-A4D8-3B339F8C9630
Third party plugins
None
Rhino plugins
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.12.18317.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 5.1.2015.132
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.12.18317.12076
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.12.18317.12076
/Applications/RhinoWIP.app/Contents/PlugIns/Alerter.rhp “Alerter” 6.12.18317.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.12.18317.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.12.18317.12076
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.12.18317.12076
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.12.18317.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.12.18317.1002
That’s an issue that seems specific for the Intel HD Graphics 4000 GPU. We’ve been able to identify when code was added that causes this bug and are working on a fix.
Thanks Wim!
