Don’t know if this is already discussed.
Movie attached describes a problem where objects are not shown until they are selected.
Zooming in doesen’t make them show either.
The problem occurs sometimes and is fixed if the document is closed and then reopened. (that’s why I attached the movie.)
So the problem isn’t repetable in that matter.
I’ll try tomorrow,
It’s a collegue that has had the problem from which I recorded the issue.
hopefully he hasn’t closed it down and I can collect the info.
Otherwise I will have to wait until next time it pops up in the department.
We have uppdated the grafics and still the problem occurs.
Here i a new systeminfo where the problem occurs.
I could send more videos, but in that case I will have to send it as private files.
It has happened in 3 computers the last 4 days at the department.
The only ting that we have found out as common is that the problem occurs somewehere after changing in “Annotation Styles”
Hello - another thing to check is the size - 3d size of the model - if you zoom extents and look at the camera coordinates in the Properties panel, are the numbers reasonable?
In Windows Device Manager > Display adapters, I suspect you also have an Intel chip with an old driver.
Right-click on it, properties, Driver tab.
What’s the date?
Don’t know if it applies here, but I had this problem, discovered I had inadvertently selected “selected objects only” in my render settings for the viewport. unchecked that and was good to go. Easy solution, that might not apply to your situation … . Good luck !
All graficdrives are now up to date.
The problem is still there dough. But now we can reproduce the problem.
I have a new movie to upload, but this contains confidential material. Where do I upload it?
What we have found is that it seams to happen after we change something in the options->annotation styles like length units-> length factor or so.
After this we select a paperspace and then all lines disapers. selecting them makes them shown again
