Rhino 6 Display Issues (Native Windows)
Hi Everyone,
I am having display issues with Rhino, mainly Breps and Meshes (imports and Grasshopper bakes included). For some reason, when on Shaded/Rendered mode the geometry appears to be invisible but displays properly on Wireframe mode.
I am assuming it might be related to the preview/render meshes not being built. Sometimes, if I select an item and zoom into it it seems to suddenly appear, but this doesn’t always work. It is causing me pain and not sure if it is a software issue or display from my end. I have the latest NVIDIA driver installed and I have uninstalled/re-installed Rhino 6. This issues don’t happen when saving the file as Rhino 5 and opening it with Rhino 5 on the same computer.
Specs below:
Rhino 6 SR6 2018-6-26 (Rhino 6, 6.6.18177.16151, Git hash:master @ abeff9e9af62a0e02a9eb52efa77e179a682f2c7)
Licence type: Commercial, build 2018-06-26
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: H-VR
GeForce GTX 1080/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 398.36)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-24-2018
Driver Version: 24.21.13.9836
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.6.18177.16151
C:\Program Files\Geometry Gym\Rhino3d\BullAnt.rhp “bullant” 1.3.7.0
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.6.18177.16151
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.4.13.574\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.6.18177.16151
C:\Program Files\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino.Plugin” 2.3.18192.1454
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.6.18177.16151
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.6.18177.16151
Please load-protect (disable) third-party plug-ins BullAnt and Enscape, restart Rhino and see if things work any better.
If the problem persists please export such an object and attach here. If you’d rather not share in public you can use rhino3d.com/upload and copy the link to this discussion into the comments box.
Hi Nathan,
Thanks for your quick response.
I have disabled the plugins and, while there were minor improvements, it still fails to fully load the meshes. I have uploaded the 3dm file using the link.
I see the problem. I have logged it as RH-47297. Thank you for reporting.
/Nathan
