hello forum, 2 questions about extra display modes
- is it possible to import the ini files of the blueprint and blackboard display modes into Rhino Mac, if so, how ?
- I have attached a screenshot of a blended display, is this possible in Rhino ?
No idea about this!
Probably possible, but this is most surely done in Photoshop, Illustrator, or any other graphics program. The backplate here is probably a photo and the lines where drawn over it. The background was then faded out with a white to transparent gradient or something.
If you start from a Rhino model and don’t have any photos, you can setup a view/perspective and save it. This is important for lining everything up later!
In this viewport, you now perform a Make2D command on your 3D model to get all visible lines only. After that you can adjust some inaccuracies and add for instance window hatches like in the above example.
Then you need to produce a rendering from the exact same view in Rhino Cycles or any other 3D app with rendering capabilities.
The last step is overlay everything, let’s say in Illustrator, and introduce the fade out effect.
Hi Miles -
thanks for chipping in Wim, yes the blended view I did in Vectorworks was a similar method to what you describe here, I’ll have a play in Mac WIP too
as for the blueprint and chalkboard display modes for Rhino Mac I’ll keep my fingers crossed for a fix soon, cheers
