That woudl be VERY nice.
Acutally a question in this context is. What is the option to establish this kind of display of hidden lines in a custom display mode?
Hi Tobias - Sorry, I do not have any good news for the short term - the dashed line drawing is simply broken in V6 and V7, says the developer. The display modes that do not have Technical at their base do not have this hidden line capability at all, so I am afraid you are stuck. The best I can do for now is make a bug report to get dashes drawing better.
Well, then I would be very happy if you’d make a bug report.
How realistic is getting this working? I would not assume that it’s not very realistic because it seems to not be working in V6 as well, right?
@pascal
I see. Strange why nobody else complained about that before.
In my eyes this display mode is really, really (I cannot emphasize this enough) good and will mamke my life a lot easier.
As the lines do not have to be dashed (at least right now), but I wanna see the hidden lines in terms to create a drawing out of them. Of course I could use “Make2D”, but this is a bit unsustainable in my eyes (at least for me). The reason for that was discussed a long time ago here: Technical drawings - Is LAYOUT the best way? and I guess maybe even for reasons like that the technical display mode was created by you guys.
What I could live with would be if the hidden lines were continous. Then I would be able to set the color of the hidden lines to something gray-ish and I think that woudl be perfecly fine, as they should simply be printed as continous lines then. (Unless some day I would be able to see them dashed).
Is there any option to change the linetype of hidden lines in Technical DisplayMode by the user?
Hi Tobias - no, I’m afraid that the settings you see for ‘Lines’ in technical based modes are ‘it’, there no more that I know of that would affect what you need.
Okay.
If I may ask (hopefully) one last question.
Is there any other way to make hidden lines visible in any way?
This would be a tremendous help, because I do not want to switch to any other software for doing techincal drawings in the future.
It does not even have to be like in a “standard” drawing, but I fear people at least want to see something like hidden lines to have a better orientation. In the worst case I will have to create a lot of clipping planes. But in general I think there a lots of people out there that wish for function liket hat.
You would probably have to use the Make2D command, to create a flat, 2d version of your perspective view curves, and place the results off on the side of your Top viewport.
Then in the layout detail, you could Zoom in on it.
It would not be using the Technical working display mode at all.
@John_Brock, okay.
I have to say though, that using the original and not the 2d-derivate has major advantages. For instance you would not be losing the information and could automate leaders that automatically get blocknames, etc…
Sorry for the stupid question again: so that means there is no display mode that I can see “hidden” lines in except “Techincal”, right?
Correct. It is only a “working display mode”, and uses OpenGL display techniques to create the illusion of a Technical display with object and hidden lines.
Open means the developer is aware of it and has looked at it.
Future means the current technology probably can not support the requested enhancement, so major new coding would be required, and it is not actively being worked on for V8.
Most of the developmene effort is going into Mac Silicon processor and Metal display support.
So still on the list, but don’t expect anything soon.
I think this topic is very important to develop a well functioning 3D based hidden line display which actually should also export to vector and not raster images when printed to pdf. I was hopeing for something in R8 but so far I could see anthing. Please put it on the list.
What I don’t understand is that it take so long to fix or find a workaround. VisualArq is showing it that a well functioning hidden display mode works and exports to vector graphic simply installed as a plug in.
But I wont install VisualArq permanently just for a display mode if I cannot make use of the rest.
So please bring this issue up again towards an fast fix for R7 and R8!
