Display Bug
Getting a weird display, that also removes the geometry.
Hi - please post the result from the Rhino SystemInfo command.
Just getting back into work. SystemInfo is returning unknown command. Thank you.
For older versions of Rhino, please post a screenshot of the Rhino Options > View > OpenGL page.
i’ve tried to figure out a way to replicate but i can’t. here is a file that show what happens.intersection.3dm (49.6 KB)
I’m not sure what to look at in that file. Why is it called intersection? Why was the first screenshot called Annotation? Is there something specific you are doing when (what?) happens?
oh, it happened to both files. there’s nothing i could figure out as a common command that makes it happen.
when you open the file do you see the wireframe for each box is a light grey color and is unselectable?
That doesn’t happen here, no.
Does this happen with your file as well when you start Rhino in Safe Mode?
ahhh, yeah it opens fine in safe mode. maybe i have a bad plugin? thanks
That could be an explanation - I would start by disabling all plug-ins that do not ship with Rhino and see where that gets you.
good deal, thanks Wim
yep, looks like it was a plugin called ClippingBox. thanks again.
