This is happening on several files, at first I thought it to be just the larger files I was working with but now it is appearing on this very small file:
Hi Tristan -
Is this something that just started happening, and if so, what was changed on your system prior to that?
When you start a new file from a factory-default template and create a box, do you then also see this happening?
