Rhino 7 for now.
I’ve attached the project below:
DisplacementMapScalingCollapse.3dm (1.5 MB)
Thoughts welcome, thanks!
Rhino 7 for now.
Hi @djhg,
Redo the spherical texture mapping and adjust the widget. I’d also use a better displacement image. I painted a quick one for you from your texture and will include it here.
I hope that helps.
You could do a sub-object displacement to only displace certain surfaces in the polysrf.
Thanks Brian. My results from adjusting displacement on individual faces hasn’t got me there at this point:
The selected faces have displacement turned on. The left one has the squarest edges, but at the expense of any displacement on the horizontal surface. The centre one is back to the rounded edge I’d like to get away from. In the right the surfaces have been exploded.
That’s all the expected results given those three scenarios. Two additional ideas for the top stone ring would be to either model a different surface shape to see if you like that displacement better or to model the individual stones and give each their own displacement with a stock procedural texture like fbm or noise. I think the latter will look the best… here’s a sample. The displacement uses fbm on a SubD box with the mapping set to Planar UVW. Then a simple stone image for the color texture in the material is box mapped in WCS. Adjust the size of each SubD and tweak the Planar UVW widget for variety.
Rock on ![]()
Forgive me, this may be a dumb question as I don’t do this kind of work. If you want squarer edges, why not start with a larger rectangular profile to your torus, and use some negative displacement?
Second dumb question: I see you are applying a bump map to your material as well as using the displacement map - is that deliberate?
Regards
Jeremy
