Thanks Kyle. I’m not sure where that’s set. However if I use smooth (which may have the same effect) on the current extracted render mesh with settings strong enough to get rid of those wrinkles it smears the texture like so:
Actually it turns out that reducing the number of polygons with the mesh command can be tuned to smooth the poles without smearing the colour mapping, but it leaves a few jagged holes in the mesh closer to the equator:
True. Turning a sphere from wood will result in a rather smooth, possibly even very smooth finish, once waxed, oiled, or otherwise treated for longevity - so there is no perceptible relief around the perimeter, unless one sits somewhere inside the wood grain ; )
This is a test for creating drawings of an object to initially to be presented and then for construction. With both elevation and section edges following the irregularities of the texture more or less to scale.
I have done this in some cases already, semi-succesfully (I only yesterday determined how to get the mesh irregularity to match a bitmap-rendered texture). I’m currently seeking to better understand how to control the results.
I work in the film industry where the final finish is often sculpted on to achieve an exaggerated texture, often of a wood grain; precise realism is often not the result. (On recent projects the “wood grain” has been applied with plaster, for example. Sometimes to emulate heavy aging and deterioration.) So I’d like to be able within rhino to depict how much textural relief will be applied and show how it will look.
one, using the displacement modifier that accepts a texture and then creates the displacement. All the controls are then controlled directly in the displacement panel.
This is a an example of that.
note this is simply the displacement… no color info is here.
if you want color, you need to add a material with the same texture that carries color info as well. in this case I simply added the existing texture we used for the displacement to the color channel of the physically based material.
even thought there is a message at the top that says “this panel is disabled” >sigh< I tried guys… but this is how it sits at the moment.
once you know all the secret handshakes it’s acutally a pretty powerful thing..
the last seceret handshake is the extractrendermesh command which can be used to “bake” the texture into a mesh that can then be exported and 3d printed.
Viewing Brian’s video several times over the past couple of days got me to where I am as of a few hours ago. I’ve been deploying the strategies you just posted. I’ve made a fair amount of progress to where I’m finessing the Detailed Mesh settings with the “Mesh” command to extract meshes of varying quality from a displacement-mapped polysurface. (I’m in R7 where the detailed Mesh settings are exclusively - as far as I can tell - part of the “Mesh” command.) I’ve even eventually been able to address the wrinkling at the poles - the issue in the original post - by adjusting these Detailed Mesh settings. But as my post of about 5 hours ago shows, I’m still getting some anomalous conditions I’d like to avoid, especially when I weld the mesh in an attempt to get the contours to display as required.
I generated an icosphere and used that as the basis for displacement. I created it outside of Rhino with about 330,000 tris, that is the one I added to your file with displacement. You need to wait a minute or two after opening the file for the dispacement to calculate.
For something roughly comparable generated in Rhino, MeshSphere with options Style = Triangles, Subdivsions = 5, then SubDivide twice, to get about 250,000 tris. The triangulation is not as consistent as the one generated outside of Rhino.
I’d like to develop a workflow where a displacement-mapped object is derived from a nurbs object. So based on your exploration I’m looking for a way to derive a displacement-mapped 300,000 polygon mesh from this nurbs sphere. (I’ve tried toSubD-and-back-to-mesh, but that results in a low res subd which smooths out the wood textures.)
Progress. Thanks to cdordoni, Triremesh works best of all.
However after transforming meshes - not only with Triremesh but the other methods attempted - I can’t get the texture mapping to display though the settings are identical on the original and remeshed meshes. I’ve attached the file in case anyone can help figure out what’s going on.
