Im trying to measure the displacement in a simple biaxial weave with karamba. I’m not sure if my script for the karamba part is ok (inputs, outputs, check the right thing). Ive set up the supports and weld the mesh, but i’m not sure how to apply the load, how much, and how to get a visual (before/after) and a value of displacement.
Eventually my goal is to compare displacement in 2 types of weaving, so the amount of load doesn’t really matter, as long it’s the same for both tests.
Thank you
