I am wanting to make a set of parallel bridges and want to analyse the beams and trusses of it. Please see below.
I have made the bridge set in just rhino. Want to develop something similar to the image using karamba. The analyse component shows an error everytime I increase he number of division points. How do I understand an arc like structure with trusses so that I get minimum displacement and maximum utilisation. Thank you!
Assuming that something is “super easy” is a bit of an insult to anyone who has put in their ten thousand hours to master a skill. Hardly a day goes by on this forum when someone doesn’t start a post with some variation of “I’m sure this is very simple but I can’t figure it out”.
I hope my post makes more sense after editing it. I am trying to understand a simple bridge design that I made in rhino(image). I am wanting to use karamba to recreate and make iterations where the displacement is minimum. My attached grasshopper file can be checked if you want. Basically, how do I get iterations that show minimum displacement.
The error you are getting, if you hover over the red bubble in the corner is the limitation of a free version of karamba. The full version will allow more elements.
If you want to build a bridge with multiple vertical elements and compare their results: assignment3_karambav2.gh (38.9 KB)
The component to optimize the solution is the following:
