hello, is there a way to disable osnaps in, for example, blocked objects? or how to disable them in some objects but allow in others?
the most common case for me is using picture frame, is a bit annoying having to disable the center or near osnap because it snaps over the picture frame object.
Hi Diego - one way out is to lock the layer that has the picture and then use SnapToLocked Toggle
to enable and disable snapping.
quick, simple and fast. Can I be your friend?
