Collaide
(Collaide)
September 20, 2024, 1:48pm
1
If Snap to locked objects is disabled, Rhino 8 will still snap to locked linked objects.
I can’t assume this is intended. Embedding it doesn’t work either. I have to explode the block, delete it from block manager, and then the “Snap to locked objects” option works correctly [But I want them linked and not exploded so this is a hassle.]
wim
(Wim Dekeyser)
September 20, 2024, 1:54pm
2
Hej Collaide -
I’m not able to reproduce this behavior in a quick test here.
Please provide both the output of the Rhino SystemInfo
command and step-by-step instructions on what to do.
Collaide
(Collaide)
October 23, 2024, 1:41pm
3
Hi. Opening up the original files I had an issue with, I am for some reason not facing it anymore. I had this issue with all layers locked previously, and I’m on the same system and the same install of rhino so I don’t know what could have been the issue.
But regardless, locking only the object but not the layer is on does not prevent Osnap from locking onto the locked object which I find unintuitive. thanks for the response though. i wish you well
wim
(Wim Dekeyser)
October 24, 2024, 12:24pm
4
Hej Collaide -
Again, this is not something I can reproduce here. The SystemInfo
data, 3dm files, and a workflow description would be nice.
Collaide
(Collaide)
October 24, 2024, 1:36pm
5
I didn’t mean to bother you. As I mentioned, perhaps I was mistaken regarding the original issue, but I can reproduce this minor issue/inconsistency.
Here is a detailed description with images of how I reproduced it:
Step 1:
Step 2:
Setting up file 2
Selecting the red layer, in which I will insert the file.
Step 3:
Inserting File 1 in File 2 using these settings
Making sure it’s in the Red layer
Step 4:
The File is now inserted in the red layer, as a reference.
Step 5:
Toggling the “On” option for Red Layer hides the inserted file
Step 6:
Toggling the “On” option for the linked inserted file also hides it
Step 7:
Making sure snap to locked object is disabled
Step 8:
When I lock the red layer Osnap doesn’t work on the object.
Step 9:
When I lock the inserted file, I can’t click on it or move it.
As you can see, when I lock the inserted file, Osnap still snaps to it.
Sorry to bother you.
In case it’s relevant, here is all the information from the system info command in Rhino:
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Evaluation, build 2024-10-08
License details: Stand-Alone
Expires on: 2024-12-29
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.13
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Ti (NVidia) Memory: 8GB, Driver date: 8-14-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.94
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2024
Driver Version: 32.0.15.6094
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.220\Ladybug.RH.Loader.rhp "Ladybug.RH.Loader" 1.38.220.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.51.2\Pollination.RH.Loader.rhp "Pollination.RH.Loader" 1.51.2.0
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew_V8.rhp "BlockEdit" 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp "IronPython" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp "Grasshopper" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
wim
(Wim Dekeyser)
October 25, 2024, 12:58pm
6
Hej Collaide -
Please run the Rhino Reset
command and then click the Save Settings for Support… button. Then cancel the command and post the “RhinoSettingsForSupport.zip” file here.
