Using Rhino for Mac V5.2.3.
Is there any way to disable the double-click to edit block feature? Sometimes I accidentally double-click, and if there happens to be a block hidden under the object I am attempting to select I will automatically go into block edit mode. This also happens when I single-click with the left mouse button then accidentally single-click with the right mouse button.
I am thinking of a simple toggle similar to changing the behavior of the click-and-drag feature.
