When I upgraded to Rhino 8 SR 3 I noticed a new denoiser that shows up in the raytraced mode in the viewports and in the production render window post effects. Can this be permanently disabled? I can’t find a way to turn it off in the raytraced viewports and in the production render window it is always on and checked for each rendering after turning it off in the previous rendering.
Hi Marc - the setting should be saved per file - so if you turn that off in your template files and save (SaveAsTemplate) , it should stick for new files created with that template.
