How to default Denoiser Plug In
Has anyone found a way to auto activate the denoiser while rendering? Instead of checking the box for each time you render.
Thanks
Hi @Candace_B ,
You could start a new file > Render with nothing modeled yet > Enable the denoiser in the Render window > Close the Render window > Choose Yes to save the post effects to the document > Use SaveAsTemplate to overwrite the document template you started with.
This way when you start a new file with that template the post effect setting will already have the denoiser enabled.
Oh Perfect! This helps me make better quality animations in MatrixGold.
Thank you so much!
@BrianJ
