Lets say you create a rectangle box. Each side can be measured to provide a visual number. It appears the default units for both metric and inches is two places after the decimal point.
Here is my question: How can I change the number of units available after the decimal point? I need four (4) places to do this next project.
Hi Mark - the precision for display of distances etc. as from the Length command is set in DocumentProperties > Units page, near the bottom. Set this in your template files to have it ‘stick’ for new models (See SaveAsTemplate) Precision in dimensions is set per dimension style.
Also, a bit off topic, but since you mention that you need 4 decimal places for showing the dimensions, please make sure that your file tolerances are at least one order of magnitude tighter than that.
