I have a model built in mm but have um scale geometries. So when I measure distances I get something like seen in the attached picture (0.06 mm). The thing is that I want to see at least two more decimals. So, how do I increase the number of decimals shown (which might not be the best solution because I may end up getting 4, 5 or even 6 decimals) or how do I change the scale (to um) of just the value shown in the dimensions (therefore I would get 59.8 instead of 0.06)?
Hi Rui - please post and example file - note the change needs to be made in the annotation style that applies to the dimensions you’d like to change - there are several, by default.
I’m not sure what you mean by “in the annotation style that applies to the dimensions you’d like to change” but I’ll create an example file with this issue (?) and I’ll upload it ASAP.
