Dimensions placed on leaders - how to move the dimension text?
Often with smaller dimensions, the dimension text will be placed in between (on top of) the leaders and will look messy and difficult to read.
Is there a way to either format the dimension style to place the dimension text outside above one of the two arrows rather than centered?
I work around currently by exploding the particular dimension (which looses me the proper locking filled arrow tips) and moving the dimension text manually.
Another workaround I use currently is to add spaces in front of the dimension text in the object windows in the dimension field “<>” looking like " <>" which will move the text to the right (no way of moving it to the left I found).
Both these workarounds are of course tedious and worst, they will break the dimension’s consistency and create a lot of clean up work and potential errors.
Any input from you guys who create technical drawings with Rhino for Mac?
There isn’t anything automatic but the best work-around is to turn on the points of the dimension and move the text point to a place where it doesn’t obscure the dimension lines.
Hey Wim, this is EXACTLY what I was looking for :wink:
This gives so much freedom over the dimensions and best of all will not break the dimension.
Thanks!
How i can turn on the points on dimension ?
thanks menos
