A few dimension requests:
- When making small dimensions, the arrows are automatically flipped outside (which is OK I guess), but it leaves a gap on the inside (middle example below). If the user does not want the gap on the inside, you have to increase the dimension style’s setting for “Dimension Line Extension”. This will slowly increase the lines inside until they close (2nd and 4th examples). However, the same setting adds the extension lines outside the main bars on wider dimensions where this was not a problem (not shown). Is there/ can there be a default extension line always inside the main bars?
If a user moves the dimension text, can a leader line show up? I guess for the multitude of users this may be a nuance, but currently it’s drawing a polyline for each small dimension that has to move (5th example above).
Do/ Can leaders have settings for where, by default, the text should be aligned? I would like the text always aligned upper left (top example). However, if I make a leader currently and the arrow is on the right of the text, the text is left bottom justified, which I do not want (bottom example). Currently I’m using a leader associated with blank text and moving it into position next to a text-only item. It’s not one leader (this is the middle example).
Thank you,
Matt
