Currently the line of one dimension goes through the text of another dimension, like this;
How do I prevent this from happening/how can I reposition the dimension label/text?
Select the dimension, f10 to turn on points, select point and move it.
Doesn’t work, that will move the line extensions and arrows as well, I only need to move the text label.
Choose the point directly in the middle of the text.
Ah, I’m an idiot. Thank you!
It would be useful if there is an option to add a leader line from center of the dimension to he value in case value is manually moved away. Autocad has it. It is a must for good drawing creation.
