Hi all,
I would like to know if there’s a reason or a logic behind the fact that Rhino’s layouts can not get accurate dimensions of detail views set to anything other than plan views ? If you try and create dimaligned dimensions of an isometric detail view. the numbers are totally off with no real logic to it.
I believe it’s been like this for as long as I’ve used the software, and I got used to working around it, but as I was training a friend recently this issue popped up, and he was really surprised of this behaviour which is not consistent with other CAD software’s behaviour. And frankly a bit quirky.
Made me think how much time it would save if I could get dimaligned to work in the layout space with perspective and isometric detail views. Any chance that could be solved McNeel ?
Here’s a piece with dimaligned in layout space :
Same piece with dimaligned in perspective view :
Thank you for your thoughts on this issue,
Sincerely,
Joaquim
