hey, I have problem in rhino7 that the dimensions, hatches, texts don’t show up. I tried change scale or the font but nothing. When I try to do new file it is the same.
thanks
Hi Josefina,
Can you run SystemInfo in the Rhino Command line and post your results? Thanks
That looks OK.
Can you post a small example file? Thanks
example_file.3dm (133.6 KB)
not seeing anything abnormal.
Lets run the ResetPreferences command as well as update to the latest (7.36)
It works! Thank you so much:)))
