Hi, I have attached a file. When I make a linear dimension between the two points in the circle and pull the dim off the points, it looks fine. But if I want to drop the dim right on the points, the extension lines do not recenter on the points like if did in v5. It did this auto in 5 but in 6 it does not seem to be.
I can mess with extension line offset, but that is a bit tidly. Any thoughts?DimensionQuestion.3dm (51.4 KB)
Great. Also the text gap for dimensions is not easy to find…sometimes it is there and other times it does not seem to be. Overall good improvements!
Hi Clint -
https://mcneel.myjetbrains.com/youtrack/issue/RH-52426
the developer tells me this is a deliberate change to bring the behavior more into line with… what some users apparently expected. It could be changed again, but at the risk of the pitchforks coming at us from the other directions. Hard to know what to do.
