Again a drafting question. When dimensioning in PaperSpace, often want to use the same callout for similar items in different views. If I copy the call out, it is not connected to the new item. Is there a way to connect it so if I change something it adjust with the changes?
Yes. It’s been years since I’ve put energy into it, because it’s so frustrating.
But I think someone told me once upon a time, that if you “group” the dimension to the entity you dimension, then the dimension should update if the entity changes…
The buzz kill is when the link breaks and it seems pointless.
All I’m seeing so far is ppl talking about using history. So not verified yet.
Yeah using “history” so far seems like the only way unless it’s broken.
