Dimension not showing correct measurement
The distance between grid A and B is 5000 mm but rhino is dimention is showing 9500.
how do i fix this please
Hi! Can you provide an example file please
Hi David
thanks for the reply, as you can see the distance between grid A and B should be 5000mm
Do you get the correct measurement with the Analyze / distance command?
Hello- if this isnot resolved, please Export the dimension and the objects that are being dimensioned to a new Rhino file and attach it to your reposnse.
distance command showing correct measurement.
I copied the whole drawings to a new Rhino file, and its fixed. not sure what went wrong
