Dimensions are off only at certain angles
Hi Rhino community. I am having trouble with the dimensions on Rhino 7. I messed around with some of the settings and now dimension readings are off. One dimension is correct at 6" and the same length dimension reads 10" when it was originally drawn as 6" and it should still be 6". I attached a short video to help me explain my problem better.
use your project snap, the Z Heights are different. (use SetPt if you want to fix that)
Thank you so much!
