Dimension not correct
what happened with Dimension ???
Hi Jon, from this picture I am not able to appreciate which dimension is not correct and why. Can you send the model to visualarq@asuni.com so we can check it out?
Thanks,
DIMENSION LINE THICKNESS NOT CORRECT WORK WITH VA
I WILLL SEND THE FILE
THANKS
Got the file, thanks! I can see the wrong thickness of those dimension lines. We have fixed this problem in the upcoming VisualARQ 2.3 version that will be published in a few weeks.
Hi, I’m having an issue with the preview dimension. The feet seem to be reading as inches.
For example when I type 12’ into the command the wall draws at 12’, however the dimension preview shows 144’-0" Similarly, if I type 3/4" the preview shows 9"
I am working with Rhino 5 and VisualARQ 3.6.12837 (currently the latest version as of 11/10/2018) in the feet template. This issue does not seem to be happening in the inch template.
@shor0128 You are right, there is an error with the dimension preview when drawing VisualARQ objects in document in feet. We will fix this in future versions.
Thank you for the quick reply. I’m looking forward to the next update
Hi @shor0128 I’m glad to announce we have fixed this in VisualARQ 2.12, which is available for download: VisualARQ 2 - Version 2.12 released
