Hello all,
- I wonder if making associative dimensions is working consistently on your end?
Here is a video:
When I make a cube for example I can only snap to a black highlighted rectangle which does not allow history - apparently, when I alter the cube then the edges highlight and the history works.
And the file:
Dimension_History.3dm (118.4 KB)
- I’d also like to ask if there is progress in being able to dimension inside a block?
- working with nested blocks and being able to annotate associative would be great.
- Dimension inside block not updating? - Rhino / Rhino for Mac - McNeel Forum
- And 'Id also like to know if grouping inside of blocks is still on the agenda?
If any of you has workflows that are working - I would be more than happy to learn from you.
Best regards,
sebowim
