Hi all. fairly new to rhino so excuse the basic question. I’m struggling to annotate the length of the long edge or hypotenuse of a truncated cone. Dim Aligned when used to measure the distance between mid points on the top and bottom circle only gives me the dimension in 2d, or side b of the triangle, not the hypotenuse. I can measure it using analyse distance but i would like to annotate. Many thanks. Loz
Thanks very much. this is exactly what i needed. I’ve worked out how to make a custom cplane and get the dimension but can’t work out how to return the cplane to default to continue working on the rest of the drawing. Many thanks
set cplane to world. sorted. thanks again!
