Difficulty moving Sub-D face loops in a controlled way
I want to adjust the position of a set of sub-d faces in and out by the same amount all along (same direction as an offset) but I can’t find how to do that. In my case the movement is along V I believe. When I select the faces as shown, MoveUVN has no effect. Same thing if I select the vertices, I see an effect only in N. I also tried sliding the top and bottom row of edges but when I do that the top edges do what I want, i.e. they move along the white arrows in my image, but the bottom edges move up-and-down (along N?) instead of moving in the same direction as the top row. Sliding the edges would work if I could set the bottom edges UVN directions the same as for the top row. Thanks for helping me figure this out.
Best to upload your file, so forum members can examine it, and find out what the issue is.
at the moment we do not have the ability to edit on a per face basis.
global scale is the best we can do currently, however this is an open request.
OK thanks. I slid the two edge rows in turn. Cheers
